Spun bushing annealed hardened steel shaft?
I've got a steel shaft where we lost an oil feed and subsequently overheated a Vespel bushing. Not only is the bushing trashed, but the steel shaft got so hot that it appears it could have gone through some phase transformation, possibly annealed.
Based on the colors we can see on the shaft, and a basic heat treat/annealing guide (http://www.threeplanes.net/toolsteel.html - I am not a Materials guy) it looks as though the shaft could have gotten up to 500-600 deg F. The shaft is 4340 Alloy steel, heat treated to about 50-60 Rockwell C.
As I said, we expect that we lost the forced oil feed through the bushing, so the shaft would have simply cooled through room temperature air. Could we have annealed the steel in these temperature ranges? If so, would that mean that we've lost some surface hardness? What temperature would we expect to have problems with 4340 that had been heat treated to 50-60 Rc?
Thanks for your expertise!
Brad
Brad
RE: Spun bushing annealed hardened steel shaft?
Plymouth Tube
The original post was in F, not C.
Brad,
Without a hardness check, you will never really know since the oxide colors change based on length of exposure and the environment. They can provide a ROM guess at best.
