Hastelloy 276 in seawater
We're looking at a pressure transducer made from Hastelloy 276 as part of a control system in a seawater environment and I was looking for any information in regards to this material's robustness. We will be both using it a sealing surface (o-ring) as well as the diaphram on the transducer.
thanks
thanks
RE: Hastelloy 276 in seawater
There is corrosion data in the C-276 data sheet on the Haynes web site.
Plymouth Tube
http://ww
http://www.desline.com/articoli/5161.pdf
http:
S
Corrosion Prevention & Corrosion Control
