Substation Outdoor Bus Conductor Max Allowable Temperature
What's the maximum allowable conductor temperature your company uses for the outdoor substation copper bus bar? 90 degree C? 80 degree C? or 70 degree C? If you use the conductor temperature lower than 90 degree, why? what're the main concerns?
THanks
THanks
RE: Substation Outdoor Bus Conductor Max Allowable Temperature
For bar conductor screw connection approx. 120 oC
For the same as above but silvered approx. 160 oC
For post insulators and bushing approx. 85 oC
Other material [as per IEC Pub.85] more than 90 oC [class A, B, C, E, F and H]
Other material [as indicated by manufacturer]:
For solid insulation bus bar approx. 85 oC
For Epoxy Resin Casting Glass Filled insulators max 130 oC.
