Hole Inspection System
Im looking for an off-the-shelf hole inspection system. I want to measure things like:
circularity
straightness
taper
angularity/perpendicularity
diameter
surface roughness
etc.
The holes I am planning to inspect will be drilled. Diameters ranging from 1/4"-1.0"
Anybody work with these machines or know of a builder that I could talk to?
circularity
straightness
taper
diameter
surface roughness
etc.
RE: Hole Inspection System
There is no "off the shelf" machines which provide everything. A CMM is probably the most universal of a measuring system available today but it has its limitations also.
Forging http://mech.e.tripod.com
Ddraig Breuddwydia....www.tailofthedragon.com
To warn you though, this will be expensive. Last one I quoted over a year ago was pushing $100K for the benchtop model.
