OCR-Part Text
OCR-Part Text
Is there a way to recognize SW part text? OCR recognizes drawing text, but can't seem to recognize part text. I'm try to do this for our nameplates on our products. The nameplates are created in the parts, and the drawing made from that. The .prt has a text functionality and assume you could do OCR when a PDF is made.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 4.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
RE: OCR-Part Text
Mechanical Designer
RE: OCR-Part Text
Certain PDF stuff is not OCR. It's actually text, exported as such during PDF creation. True OCR wouldn't know the difference between extruded text and note text, but exported-to-PDF text vs extrude geometry text is different.
-handleman, CSWP (The new, easy test)
RE: OCR-Part Text
Mechanical Designer
RE: OCR-Part Text
rfus
RE: OCR-Part Text
Best,
Mechanical Designer
