PRESSURE VESSEL DESIGN
For a drain vessel design (ASME SEC VIII, Div 1) there are 2 vertical pumps to be mounted on 2 nozzles (650 mm dia) on top of this horizontal vessel. Is any special consideration to be given in the vessel design for the pumps coming on top of the vessel?
RE: PRESSURE VESSEL DESIGN
Cheers,
gr2vessels
