Haunch Moment Connection Design reference
Dear all,
We have been arguing here whether Chapter 6 of AISC Design Guide 12 can be used for regular projects (non-retrofit) in non-seismic zones for designing Haunch Moment Connections. Could you please help on following items:
1) Can we use the force transfer model assumed in Chapter 6 of ASIC Design Guide 12 for elastic design also? I mean instead of using Vpd , Mpd can we use actual factored moments and shears ? To me it appears reasonable approach, but I might be wrong.
2) Could you please tell 2-3 good references for design of Haunch Moment Connections? In our case Haunch web is welded to bottom flange of Beam and bolted with end plate on Column flange.
I appreciate your input on this.
SKC
SKC
