Will NX2 load on a XP-64Bit OS
I just bought a new computer with XP64 bit OS on it.   Will I be able to load NX2 on this system and have it function properly?  Thanks in Advance for any help.
RE: Will NX2 load on a XP-64Bit OS
I don't know of any reason why it wouldn't.
It only takes a few minutes to install. Why don't you try and let us know where you get stuck if you get stuck.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
But it will be installed as a 32-bit image, since NX2 wasn't produced in a 64bit image. So you still have the code limitations of the 32bit image.
Ben Loosli
