StormNET Error Messages
I just recently started using StormNET for hydrology and hydraulics modeling. I built my network and assinged drainage areas to each inlet. I ran the program and it gave me an error message that aplies to each inlet. It reads:
"Error 601: Inlet CB-1 has invalid by pass link at line 86 of [div_inl_props] section:"
Does anyone outer know what this means? In general does anyone know where I can find an error code list for this program? Thanks
RE: StormNET Error Messages
BOSS has an excellent technical support system. A call or email to tech support may be worth while.
Thank you guys for your responses. Yes, the support staff at Boss was very helpful. Once I was pointed in the right direction by them, I was able to answer my question and others I had regarding my model. So far, the program seems be very user friendly. Thankfully, I started the use of the program with a small project. I imagine I can get more involved as the project gets larger. If any of you have any hints as experienced users of the program, they would be greatly appreciated. Thanks again.
