Sizing PSV for fire case without latent heat
My question is simple but the answer probably is not. Can a PSV be sized for the fire case when the latent heat is not known for the liquid?
Thank you for any response.
RE: Sizing PSV for fire case without latent heat
Check out the following links to know how to determine this important property with simulators:
http://
htt
"We don't believe things because they are true, things are true because we believe them."
