"Command: _import Unable to read the ACIS file.."
Exported geometry from Solidworks as an ACIS (.sat) file.
Tried to import it into AutoCAD, got the message above.
Same results from both AutoCAD 2008 and 2009.
Not one damn clue given by AutoCAD about what it doesn't like about the file.
Generated a 3D box in AutoCAD, exported as .sat file.
Compared that to the file produced by Solidworks. Of course they are very different sizes, but the format seems similar.
No, I don't have MDT, so I can't import an iges file.
Any other ideas?
Any other ideas?
Mike Halloran
Pembroke Pines, FL, USA
RE: "Command: _import Unable to read the ACIS file.."
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Thanks!
Mike Halloran
Mike Halloran
