Assembly Sequencing
Assembly Sequencing
Assembly Sequencing
I'm in NX5 trying to sequence a fully constrained assembly.  I can enter the sequencing workbench by selecting Assembly Sequences from the Assemblies toolbar and then create a new sequence by selecting "Create New Sequence" in the Sequence Navigator.  After that however, I can't seem to find the camera, motion, disassemble, etc. picks on the toolbar.  I attempt to do an Extration Path and I get a dialog saying mating constraints will be turned off.  I select yes and then I get a message saying the Path Planning License is not available.
Is there a specific option I need to have in my software?
Thanks...
Fighter Pilot
Manufacturing Engineer
RE: Assembly Sequencing
In order to use the Extraction Path function you will need to purchase the 'Path Planning' module.  Since this function uses code licensed from a 3rd party and to whom we are obligated to pay a royalty for each seat sold, we could not automatically include it as enhancement to Assembly Sequencing without first having to pay a royalty for every seat of NX currently under maintenance.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
John,
Can I create any assembly sequence?  I can't even find the camera or insert motion functions?  Are you saying I need this module just to do the basics?
Fighter Pilot
No, simple Sequencing only requires an Assembly license.  I can't find any situation in Sequencing where those items are not available unless you have explicitly hidden them using Customize.
John R. Baker, P.E.
Cypress, CA
John,
I found the icons.  There were buried under some custom layout I had going.
thanks...
Fighter Pilot
