Welding SMO 254
Welding SMO 254
Welding SMO 254
Hi guys,
I have to weld a sheet of S32254 (ASTM A240) to a casting made of the same material CK-3MCuN (ASTM A744). From several readings it seems it's possible to use both 5.11 E-NiCrMo-3 and 5.11 E-NiCrMo-12 consumable electrodes. Does anyone have some experience and knows advantages/disadvantages for the two solution?
Thanks in advance
Domenico
RE: Welding SMO 254
The main disadvantage of using Nb bearing alloys to weld either the 254SMo and the CK3MCuN is that the Nb in the filler metal combines with the N in the base metal to form nitrides that can be embrittling.  It is contained in some of the Avesta literature.  However, it is commony done.  I have experience the most problem when a customer specified that NiCrMo-3 was mandatory, and solution annealing was also required for repairs of CK3MCuN.  There were many tensile and bend failures on weld test due to that.  In the as-welded condition, it isn't as much of a problem.  However, if I have a choice, I choose NiCrMo-10, which has plenty of Mo and no Nb, and avoid the risk all together.  It is a bit more expensive though.
