About impact test , mdmt reduction
1. internal press.:2.8kg/cm^2
2. external press.:11.55kg/cm^2
3. required th'k(for int.): 9.63mm
4. required th'k(for ext.): 42.59mm
5. M.D.M.T: -29 deg C
6. material : SA516-70N
On compress program, the internal required th'k is criterion of Curve reduction according to UCS-66.1 ratio.
But governing th'k is got from the ext. press.
Although governing th'k is the required th'k for ext.press.
i wanna know why the internal required th'k is criterion for MDMT reduction. Please inform me which part of Asme code is marked about contents as above in detail.
