Transformer testing
Transformer testing
Can you suggest what is more advantage or helpful in Transformer testing, doing insulation resistance test or insulation power factor test.
Thank you.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Transformer testing
Power factor test set = $$$
Insulation resistance test set = $
Hiring a competent testing contractor to show up and do the tests usually means you get BOTH tests anyway. They are part of a pretty standard battery of tests on oil-filled transformers above a certain size.
old field guy
Thanks!
megger - DC
PF/DF/Tan_D tester - AC
Load break switch , by its name - can interrupt the load current but not the fault current
