cost of valves
cost of valves
cost of valves
how to determine cost of various sizes of valves including ball,gate,globe valves with class 150. is there any thumb rule like "cost/inch"
RE: cost of valves
More reliable: cost/weight
Use weight multiply by steel price and use a factor (e.g. 6) and this will do as a "installed price" for a rough estimate (process piping)
Best Regards
Morten
RE: cost of valves
THANKS MORTEN BUT PLZ MORE ELABORATE THIS. HOW TO FIND WEIGHT OF 12 INCH DIA GATE VALVE CLASS 150
RE: cost of valves
Try a cataloug or talk to the vendor.
Many valve manufactors has great web sites with all sorts of info.
Try google if you dont know any manuf. by hart or talk to a colleague wich manufactor you usually use.
Best Regards
Morten
RE: cost of valves
If you're trying to build a spreadsheet or program that estimates your valve and pipe weights/costs based on nominal size and pressure I don't think your results are going to be all that accurate. Valve costs/weights will vary considerably depending on type, trims quality level, and so on.You might try building and maintaining a separate database or spreadsheet with weights and costs direct from your vendors, then drawing your values from this into your estimating spreadsheet.
RE: cost of valves
we are talking +/- 40% here (thats my suggestion weight/installed cost)
Best Regards
Morten
