SAE flange dimensions
Hello all,
I'm looking for a dimensional reference for an SAE 5 hole pattern flange. Plenty of ANSI/ASME refs out there but could not find any for SAE.
Maybe they are one in the same?
Thanks in advance.
Thanks in advance.
RE: SAE flange dimensions
Mike Halloran
Pembroke Pines, FL, USA
Typically I would receive a spec for a 1" 150# ANSI flange for example. This customer has specified an SAE flange instead.
I was looking for a chart that would state the bolt circle, flange thickness etc...for this standard.
Timelord
They have standards for hydraulic flanges, but those have two or four bolts.
... Ah. There IS such a flange, as used in level sensors like this:
http://www.e-components.net/Remotefuelsender.htm
Unfortunately, the page doesn't reference _which_ standard applies. You might be able to find it by searching
www.sae.org
Mike Halloran
http://www.sae.org
They have flange standards for automotive and aerospace applications.
