Shear Wall-Steel Beam Connection
I'm designing a steel building on which steel braces are used for lateral on one direction and shear walls (elevator and stair shaft)on the other. How do I connect the building to the shear walls core. I have seen it with a steel plate with welded Nelson Studs casted inside the core. After the cores are cast, steel plates are welded to the plate already anchored to the concrete and connected to the steel beams. Is this the typical way of connecting core to the building..
RE: Shear Wall-Steel Beam Connection
Mike McCann
MMC Engineering
Mike McCann
MMC Engineering
Thanks for your input...
