Should I study Msc Civil Engineering OR Msc Water and waste water Engi
Please can someone advise me on the best option for me. I have a bachelor degree in Civil Engineering and I want to study for a masters degree. I don't know which would be be better Msc Civil Engineering or Msc Water and wastewater Engineering? I like both but I want to the make the right course considering employability(based on securing a job after completion). I intend to relocated to Australia after some years in the UK. Not working for now. Please advise me
RE: Should I study Msc Civil Engineering OR Msc Water and waste water Engi
If you want to work in the water industry then the Water and Waste will serve you better. If you want to keep as many options open as you can, then go for the civil. I took the first option 6 years ago and its worked well for me
