90 degree inside corner soldier pile configuration
I want to know in normal practice how other engineers configure inside and outside corner piles requiring anchors? For outside corner pile, in order to eliminate use of anchors for the pile I normally use a number of straps using 4x1/2 steel bar welded on flanges of adjacent h-piles each direction. In this case, the straps will work as a tension member like anchors and I also check bending of h-pile section in weak axis. Do you have any idea for inside corner pile? I may use a small tube section as a compressive member though, want to see if there is any better way to do it. Thanks!
RE: 90 degree inside corner soldier pile configuration
