Attribute Link Text - No Units
Hi all,
Linking parameters of length values to a text box in drafting, I can obviously create a dynamic link to the parameter, so if the part changes the values in the drawing update.
In this example it is coordinates of 3D points for a pipe drawing. The coordinate dimension table is not associative.
But using the attribute link command unfortunately displays the units too. Is it possible to hide the units, as obviously I don't want my dimension table with units.
So, parameter in part = 25mm
display in drawing as = 25
Thanks in advance.
Jon Reynolds
Thanks in advance.
Jon Reynolds
Jon Reynolds
RE: Attribute Link Text - No Units
The text is in a table... properties of table > text > display unit (uncheck)
Done.
Jon Reynolds
