API plan 62 - steam Quench with orifice
Please advice whether Seal plan 62 (steam quench) scheme can have Restriction Orifice for reduction of available steam header pressure to required pressure for quench.
RE: API plan 62 - steam Quench with orifice
Yes, it can but I would still use a needle valve or similar upstream of the orifice. Depends on what orifice diameter you will use and header pressure also.
normally orifice size for API plan62 Steam Quench is 1/16" (1.5mm) and API Plan11 is 1/8" (3.5mm)
Yes, orofice can be used. No. of orifice will depend on desired pressure drop. Normally 3 to 5 psi pressure for plan 62 is good enough.
Instead of orifice a needle valve with small opening will be better choice.
