japanese engineering symbols
On a japanese print, if the surface finish is called out as "50Z", what does the "Z" stand for?  Any input would be greatly appreciated.
RE: japanese engineering symbols
Z is also known as Rz is expressed in micrometers and defined as the difference between the mean value of the 5 highest profile peaks minus the mean value of the five lowest profile peaks of a sample length taken across the surface under study.
