Fixing Context of Parts
Due to some connectivity issues with our customer, we were recently forced to work locally on an assembly that is in Enovia. After the connection issues were fixed, we used the checkout/checkin process to update the assemblies in Enovia. We then open the assembly from Enovia and fix all the contextual links on the parts to point to the appropriate instances in enovia. When we click save, catia loads all of the local assemblies and tries to save them to Enovia (which gives us "part already exists" errors). If we check the links, nothing points to our local drive, the context is correct. Any suggestions?
RE: Fixing Context of Parts
I guess is a problem with the UUID...I suggest you to use a step export of your assemblies and import in Enovia (if its possible but you have to be very careful because obviously you will overwrite some files) - hope I understood your problem well.
Fernando
Medicman
Fernando
I have found a workaround to be able to save, but the link still exists.
Medicman
