Turbine compressor sizing??
I don't know if this is the right forum to ask this, but I need some help.
I want to determine the right size (and a potential supplier) for a AIR turbine compressor.
The application is:
Input pressure: atmospheric
Output pressure: <20psi, <35psi at "stall"
Power to drive it: 0.1 hp
Preferred rpm: <25,000 (but can go up to 100k if required).
I have machining capabilities, so if there is likely not a supplier of a completed standalone pump, then a supplier of blade and diffuser rings would help.
Thanks in advance.
mcollins@collinstool.net
The application is:
Thanks in advance.
RE: Turbine compressor sizing??
Engine and Turbine Forum
