Belarus pipe dimensions
Hi there, here I am with another question.
Our Belarus client has sent us his piping dimension, stating that this is what he finds easily on local market.
Now, I have checked briefly and I can't match his outer diameters neither with EN standards, nor with ANSI/ASME.
I have also checked JIS, DIN and DIPS, it doesn't seem to fit.
I'm uploading his table, do you have any suggestions?
Which standard could this be?
Thank you!
RE: Belarus pipe dimensions
It was most likely the Russian GOST Standard.  That is the standard that was used in Lithuania when we were there.
Here are some of the GOST Standards that you might want to look for:
GOST RUSSIA STANDARD
Smooth Seamless Steel Tubes
GOST 8731-74 Seamless Hot-Deformed Steel Tubes. Technical requirements.
GOST 8732-78 Seamless hot-deformed steel tubes. Range.
GOST 8733-74 Seamless cold and warm deformed steel tubes.Technical requirements.
GOST 8734-75 Seamless cold and warm deformed steel tubes. Range.
GOST 9567-75 Precision tubes steel. Range.
GOST 9940-72 Seamless hot deformed tubes made of corrosion resistant steel.
GOST 9941-72 Seamless cold and warm deformed tubes made of corrosion Resistant steel.
GOST 10498-63 Especially thin walled seamless tubes made of corrosion resistant (stainless) steel.
GOST 1060-76 Steel seamless cold-deformed tubes for shipbuilding.Technical requirements.
GOST 5654-76 Steel seamless hot-deformed tubes for shipbuilding.Technical requirements.
GOST 550-75 Steel seamless steel tubes for petroleum processing and petrochemical industry.
GOST 14162-69 Small-sizes steel tubes ( capillary ).
GOST 10192-62 Bimetallic seamless tubes. Range.
GOST 21945-76 Seamless hot-deformed steel tubes made of alloys on the basis of titanium. Technical requirements.
GOST 21729-76 Seamless cold-deformed and hot-deformed tubes made of structural carbon and alloyed steel.
GOST 22786-77 Bimetallic seamless tubes for shipbuilding. Technical requirements
GOST 631-75 Internal-external upset drill tubes with couplings.
GOST 8467-57 Drill tubes for geology-exploring with nipple connections.
GOST 632-64 Casing tubes with couplings.
GOST 6238-77 Casing and coring tubes for geology-exploring drilling and nipples to them. Technical requirements.
GOST 633-63 Tubing pipes with couplings.
GOST 10704-76 Electrically welded steel tubes, line-weld. Range.
GOST 10706-76 Electrically welded steel tubes, line-weld. Technical requirements.
GOST 10707-73 Electrically welded cold-drawn and cold-rolled steel tubes.Technical requirements.
GOST 11068-64 Electrically welded stainless steel tubes
GOST 3262-75 Steel tubes for water and gas supply with couplings.
GOST 8696-74 Electrically welded steel tubes with spiral seams for general purposes
GOST 5005-65 Electrically welded steel tubes for car cardan shafts.
GOST 11249-73 Steel rolled up soldered double-layer tubes.
GOST 12132-66 Electrically welded and seamless steel tubes for automotive and bicycle industries.
GOST 20295-74 Welded steel tubes for main oil and gas pipelines.
GOST 13663-68 Shaped steel tubes. Technical requirements.
GOST 3664-68 Steel tubes star-shaped. Range.
GOST 13665-68 Corrugated steel tubes. Range.
GOST 13666-68 Many-ribbed steel tubes. Range.
GOST 13667-68 Ribbed steel tubes. Range.
GOST 13668-68 Steel tubes with inside splines. Range.
GOST 8639-82 Square steel tubes. Range.
GOST 8642-68 Oval steel tubes. Range.
GOST 8644-68 Flat-sided oval steel tubes. Range.
GOST 8645-68 Rectangular steel tubes. Range.
GOST 11681-65 Bended stainless steel tubes. Range.
GOST 11682-65 Bended stainless steel tubes. Technical requirements.
TU 14-3-190-82 SEAMLESS STEEL TUBES FOR ELEVATED TEMPERATURES (10)
TU 14-3-460-74 SEAMLESS STEEL TUBES FOR ELEVATED TEMPERATURES (20)(12H1MF/15HM )
fedeghi,
Some of these pipedimension match to DIN standards and are used in greenhouse heating systems in western europe p.e.
DN 50=57 mm OD, DN 100=108 mm OD, DN 125=133 mm OD and DN150=159OD. In western europe matin flanges, elbow etc are still on the market. But it's no very consequent because for DN 250 the use 273 mm instead of 267.
Mr. Breen, you never cease to amaze me.  Thanks!
