Square Flange Design
Hi I am looking at finding a standard that could be used for design of an atmospheric process vessel (tank) for SG>1 toxic/corrosive products. The vessel diameter is 3m or less and will be supported on four legs.
RE: Square Flange Design
Is it a Square Seal Flange, due to assembly and access restrictions?
Mario Souza
Application & Product Engineering
WMF Solutions Brazil
http://www.wmfsolutions.com
No, these flanges are part of the steel ducting system used to recover off gas from the steel furnace. The dimensions are in the range of 1500x 1700 to 2400 square. The ducting is of 12 mm plate and the proposed flange thickness is 22mm with full face gaskets.
