GD&T true position question
Where in the ansi standards does it show the true position formula 2 * SGRT( X to the 2 + Y to the 2)?
RE: GD&T true position question
I'm not sure that it is in the standards.  You may want to ask over on forum1103: Drafting Standards, GD&T & Tolerance Analysis.
I couldn't see it in ASME Y14.5M-1994.  B4 does give the equations for calculating position tolerance from the sizes of the male/female components.
The equation you give is for converting +- coordinate dims to position, instead 14.5 concentrates on determining the pos tol from true function, hence B4.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
