Matlab audio formating
Hi all,
Im running vista and recording .wav files with the recording software offered by windows. I then import this data in matlab to process it.
When I plot the data "plot()" it returns the normal looking audio file plot (ill try to include an image). The problem is the file y axis max is from -.4 to .4 but the data exceeds these bounds. So, is there a way to fix this so that it includes all data (other than taking more samples at lower levels)?
Also there is a lot of unwanted data (no audio present). I need to remove this...edit the data so that it only includes the portion where actual audio recording is present.
Thanks in advance.
James
RE: Matlab audio formating
Looks like you've clipped the signal at some point in the recording process. That is an unrecoverable error.
Wen you've fixed that, decide on a level and a time that represents 'silence' and chop those bits out.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Thanks. I figured it was due to the vista recorder...ill try some others.
as far as "chopping those bits out" how do you edit the matrix within matlab?
ok...like new_matrix = old(old>.01)
or something...
Not really. Why not use music editing software like goldwave?
Cheers
Greg Locock
Agree, you don't need Matlab for the agricultural stuff.
- Steve
But I do. Im taking inputs from users and need to clean up the recording for processsing in order to determine cepstral coefficients to provide input to a neural network...now, I could go through the samples one by one (hundreds of samples) and cut them up to look nice...but yea...a program to do it all for me would be nice =.=
Fair enough.
Well, i'd create an nx2 matrix called goodbits with start and end of the good bits in each sample
k=1;
for i=1:n
for j=goodbits(i,1):goodbits(i,2)
noisy_wav(k)=original_wav(j);
k=k+1;
end
end
Steve will now present a one liner, probably using sparse.
Cheers
Greg Locock
Locating and removing the silent bits requires a thresholding method, something like an RMS filter is common, these are on the FEX if not in Matlab already.  Then you can use logical indexing for your chopping.
% Untested, assumes an rms() function.
idx=rms(data)>threshold;
new_data=data(idx);
Which could of course by combined into a single line if "idx" has no further uses.
Another envelope method I like is based on a hilbert transform:
idx=abs(hilbert(data))>threshold;
Just to comment on Greg's code...
This line:
will cause the array noisy_wav() to grow each time a sample is copied across.  The loop slows down as the array grows.  It's almost always better to calculate the final array size and preallocate it with zeros.
No sparse() solutions today, sorry sad
- Steve
