Problems with curve projection
3
Just wondering if anybody could help me.
I am trying to project a line onto an extruded surface.
To project the curve, I am using CURVE - PROJECT CURVE, then sketch onto face.
I pick the curve and then pick the surface. In my case, the surface I am using is a cylinder, and there are two options (either side of the cylinder) however when I click OK, the curve that is generated is on the wrong side of my cylinder.
Is there a way of forcing it to use the side I require?
The pictures hopefully show my problem.
Many Thanks
RE: Problems with curve projection
Can you post a simple jpg or something. Not everyone has Win2007 PowerPoint.
Also, have you tried the Wrap function.
one workaround is to split the cylinder into two faces using a sketch line. (insert->curve->split line) then it will project the curve on the other side.
another workaround: move the plane you sketch on, to the other side or create a plane parallel to the current plane then create a sketch on the new plane, select the curve you want to project, and use convert entities. then project the new curve.
I think that the proper solution is to put the sketch on a plane inside the vertical cylinder and then the "Reverse projection" checkbox will work OK.
Alternatively, you could make two tiny cuts on opposite sides of the cylinder to give it two surfaces, and then you can select the side you want, two one micron diameter circles on the end face with their centres coincident with the surface would do.
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2009x64 SP2.1 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2009x32 SP1.1 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.11.7751
It's good to talk
Many thanks for your responses,
MechatroPro - Using 'workaround' I want to try and keep the cylindrical surface as an untrimmed surface
'Another workaround' I tried that and the projected curve still projects onto the wrong side of the surface.
SincoTC - You're a star, I used the proper solution and it gives me the control of picking which side that I need. Many thanks
Thank you all for reading my post on a Saturday.
Keep up the good work.
sammybrush,
I'm not sure what you are actually trying to achieve, but have you investigated the Weldment function. It looks like it could drastically simplify the model.
I am just trying to create a surface model of intersecting tubes, that can then be sent to a finite element package and meshed using quad elements.
OK, so use the Weldment module to create the parts, and then create the surfaces from the weldment.
