Superfinishing
Superfinishing
I've read some recent articles on superfinishing of gears and bearings. It seems the academic studies are showing substantial improvements and it's not a gimmick. I have a few questions for those of you who have used it:
1) Does superfinishing benefit parts that have already broken-in to a decent polish, or is it mostly of value for OEMs who need to get maximum efficiency with minimal break-in?
2) Can superfinishing be used in conjuction with shot peening and not causing excessive damage to the gear profile?
3) It would seem that chemically accelerated vibratory finishing is being used for these types of parts. Is that the state-of-the art in superfinishing for a reasonable cost? (My intended use is racing, but my budget is more value-driven)
RE: Superfinishing
The last step is always burnishing the diameters with a bit of crocus cloth, and then some worn crocus cloth, or the back of the new crocus cloth.
That's what superfinishing is; automated machine, fancy strip of high tech sandpaper, similar result.
Not equivalent to shaking the part in a bucket of rocks, not even with magic chemicals.
Mike Halloran
Pembroke Pines, FL, USA
RE: Superfinishing
It looks like mechanical polishing can get that good, taken to the limit. But will it have the same surface characteristics? Will the manual tendency ruin the gear profile or cause low spots? This is why I didn't necessarily assume polishing would be as effective.
I'm more than happy to try, considering that I want to start with a couple of gears and bearings.
RE: Superfinishing
If you're going to SELL stuff to racers, anything that sounds zoomy and doesn't noticeably cut power or driveability will sell.
Mike Halloran
RE: Superfinishing
Dave
RE: Superfinishing
In gears, (as in bearings) the direction of the grinding striation/furrows has a more critical impact than the surface texture value itself. Specular finishes are not particularly great in the highly stressed contact patches in gear flanks. In helicopter transmissions, surface finish is an highly sensitive topic. Military application require survivability of gearboxes (I seem to remember 30') at full power with complete loss of lubricant. This is accomplished using several techniques, (with lubricant retention being one of them and this is accomplished by increasing the contact area while increasing the retaining volume of the lubricant). The surface in such cases is defined by the DIN symbol Sk (I believe it is still part of a development standard).
Any good tribology books will give you the acceptable finish and texture shape limits to reduce friction and wear while still be able to retain/build complete metal surface separation.
RE: Superfinishing
This idea is being reevaluated.
While I am not a tribologist, I have to say the studies mentioned in this article:
http://
I don't have any of the helicopter requirements - I'm in an automotive application where the NASCAR rear axle studies are relevant and interesting.
Dave
RE: Superfinishing
"Can superfinishing be used in conjuction with shot peening and not causing excessive damage to the gear profile?"
It's my understanding that shot peening and superfinishing of case hardened gear flanks and roots both have essentially the same effect. They improve gear life by removing minute surface imperfections where fractures/surface spalls tend to propagate from. When performed properly, neither will be detrimental to the gear tooth profile.
If you have designed, manufactured and assembled your gears and lube system properly, they should always be operating within hydrodynamic film conditions. That means low probability of scoring and a high lambda value. As long as you operate in full hydrodynamic conditions, having a super finished surface won't be of benefit. Most gears (and bearings) tend to ultimately suffer spalling failures that initiate at pits due to surface corrosion. If there is no corrosion present, a well designed gear or bearing will have essentially unlimited life.
Superfinishing and/or shot peening of gear tooth flanks and roots removes the tiny corrosion pits in those highly stressed surfaces, that are an inevitable result of the manufacturing process. I tend to prefer shot peening instead of superfinishing. They both accomplish the same thing, but I have more experience with shot peening.
Terry
RE: Superfinishing
- shot peening: induce compressive stresses in the surfaces to improve fatigue/bending strength
- isotropic superfinishing: extremely fine surface finish to boost the lambda value and reduce friction. In loss-sensitive applications where the original lambda was sufficient, this can allow lower viscosity lubricants for still lower losses.
I'm mostly interested in the superfinishing aspects. I see the REM has a chemical/vibratory superfinishing process available. There are a couple of shops I've found that advertise the service. I have yet to find a shop offering a superfinishing service other than the REM ISF method.
RE: Superfinishing
Without actually removing material, I don't see how shot peening can "remove the tiny corrosion pits in those highly stressed surfaces" as mentioned above. I've never heard of shot peening being used for this purpose.
Below is a link to an excellent article from NASA on the subject of super finishing.
http://
Ron Volmershausen
Brunkerville Engineering
Newcastle Australia
http://www.aussieweb.com.au/email.aspx?id=1194181
RE: Superfinishing
http://
Ron Volmershausen
Newcastle Australia
RE: Superfinishing
RE: Superfinishing
I have personally and actively been involved over the past four years working to qualify the REM ISF process for use on Army helicopter platforms. Bottom line: this process works.
In every test performed to date, and there have been many, each with hundreds of hours of very demanding tests, ISF has proven to improve our transmissions' performance. We have seen lower operating temperatures (20F at the sump), gear surface finish of 2-4 Ra was achieved without a significant amount of material lost... less than 0.0002 inches, reduced scoring, reduced pitting, reduced gauling, etc. All of these with no negative effects noted. There are no tribology issues, no issues at all in fact. Even the old gray beards that originally had their doubts have finally come around and admitted that the transmissons they originally designed are made better as a result of ISF application.
And FYI. I do not work for REM nor do I represent them in any way. But over these past years I have become an ardent believer in the ISF process...because a ton of testing has proven it.
RE: Superfinishing
Our gearing vendors, when asked about REM ISF, immediately responded with "we can grind to 4Ra if you want, what's wrong with that?". Obviously they have a ground finish and not isotropic, but if the roughness is the same they ask a valid question.
Have you seen tests between ground surfaces and REM Isotropic surfaces of the same Ra? Was there still a difference?
Dave
RE: Superfinishing
If a gear mesh has any probability of scoring, it doesn't matter what type of finish operations you perform on the gear. It's going to fail, and it will fail fast. Superfinishing may provide a small margin over conventional grinding/honing with regards to lambda, but it's not much. The proper approach is to design your gear mesh action so that it does not produce a situation where scoring is likely to occur in the first place.
If you've designed your gears correctly with regards to bending, contact and scoring, they will theoretically have unlimited life. In practice, corrosion will eventually occur on the gears, and it will cause small surface pits. These surface pits will eventually cause spalls in the case, and lead ultimately to fracture propagation.
The reason shot peening helps is that it eliminates/consolidates the surface irregularities that result from the rough machining and heat-treating processes. Stock removal during finish grinding of case hardened gears is normally controlled very closely. So it is very likely that some surface imperfections may not be fully removed if the surface is not improved beforehand by shot peening.
Shot peening can induce beneficial residual compressive stresses in the peened surfaces, but these are somewhat relieved during the finish grinding operations on the gear tooth flanks and roots. Of course, finish grinding of root fillets is a controversial issue for this reason.
Superfinishing can give an extra margin of safety to a good gear design, but it won't help a poorly designed gear mesh. Superfinishing of gears helps with scoring, but nowhere near as much as a properly designed lube system and lubricant will.
Terry
RE: Superfinishing
And Terry you are also right. Superfinishing will not make a fundamentally bad gear good. what we have found is that it makes a good gear better. and it can be used to remeove small pits from the gear if found early enough, and restore the gear to a serviceable condition. Penn State conducted testing for the Navy under a REPTECH effort that indicted that used gears processed using ISF out performed new virgin gears in single tooth bending fatigue tests.
ISF will certainly not solve world hunger or aids, but if you have a gear application where high torque and low speeds are involved, ISF I believe is certainly worth at least trial processing some test gears for evaluation. then, when you see the test results, you can decide for yourself if it was advantageous or not.
RE: Superfinishing
RE: Superfinishing
I agree. ISF will give a well designed gear mesh a more comfortable scoring margin. But it will not magically make a bad gear mesh "good".
I haven't seen the data you note from Penn State/NAVAIR, but from my personal experience (I currently design military aircraft power transmissions), the gears I design are analysed for infinite life in both bending and contact, and for a scoring probability of less than 1%. We use carburized/ground VIM-VAR (double vacuum melt) 9310 for the gears with shot peened roots and flanks. To get unlimited gear life, we keep the unidirectional tooth bending root stresses below about 55 ksi and the face contact stresses below about 185 ksi. In theory, these particular gears would not benefit from ISF in normal service, as your article might suggest.
The only in-service failure mode for my particular gears would be scoring due to loss of lube, overloads experienced during an OEI condition, or fractures propagating from surface corrosion pits. We design the gears and bearings to survive for a certain period of time under loss of lube conditions, we design the gears to have adequate fatigue life under any OEI condition, and we design the lube system to be factory sealed, maintenance free, and with a dessicant breather system to eliminate moisture induced corrosion.
thruthefence,
Most rotorcraft MRGB's are designed to meet a 30 minute loss-of-lube condition. The power transmitted by the MRGB during this loss-of-lube condition must be adequate to maintain level flight of the aircraft. The way MRGB gears and bearings fail in a loss of lube condition is through material mechanical failures, due to de-tempering of the bearing or gear steels brought on by overheating due to increased friction under the marginal lubrication conditions and the reduced heat transfer with no oil flow.
To meet the 30 minute loss of lube requirement, most rotorcraft MRGB's employ high temperature steels like X-53 for the critical gears and M-50NiL for the critical bearings. They also use (total loss) supplemental lube systems to provide a minimal amount of oil to critical gears and bearings.
Terry
RE: Superfinishing
When you say "X-53 high temperature steels" are you referring to 153/253/353-M alloys from AvestaPolarit?
Your use of 9310 alloy gears in "unlimited life" transmissions intrigues me. Are you familiar with so-called "Pro" ring/pinion gearsets commonly used in mega-power drag race vehicles- top fuel dragster, funny car, etc.? They are 9310 and have the stipulation of "not for highway use". I've queried some manufacturers (Richmond and U.S.Gear) about expected life if a person DID use them on the street, but the only answer was "that's not their intended usage". Any comments?
RE: Superfinishing
X-53 (trade name Pyrowear) is a carburizing alloy steel that can be tempered above 600degF, so it will maintain its hardness up to that temp in service. 9310 alloy steel is a very good gear material, but if exposed to temps above about 350degF, it will de-temper and lose its strength. The only benefit to using X-53 over 9310 is that X-53 will survive longer at the high temps experienced under something like a loss-of-lube condition.
A hypoid R&P gear set is normally limited by scoring, more so than bending or contact. So using a good gear lube with the proper EP additives and making sure the gears are set up (shimmed) correctly is the most important thing. As for the benefit of using 9310 steel, it's all dependent upon the quality of the raw material and the processing the gear undergoes during manufacture. Aerospace quality, double vacuum melt 9310 is fantastic stuff, but is very expensive. If you compare it to a commercial air-melt material of the same chemical composition, the difference in mechanical properties is like night and day.
X-53 data: htt
Terry
RE: Superfinishing
termination. The transmission was run at 50% torque for 2 hours using only auxiliary oil for lubrication. The oil in the sump reached a maximum temperature of 284.4°F during the test. An oil sample was removed from the transmission after the auxiliary oil testing. Subsequent laboratory evaluation of the oil sample indicated the transmission was operating in the normal range, at the end of the 2 hours auxiliary oil testing per NAVAIR document 17-15-50.3.
RE: Superfinishing
If your gears (and bearings) survived your qualification test procedure that ran 2 hours on an auxiliary lube system, then it sounds like your auxiliary lube system design is good. Designing an auxiliary lube system that will function for 2 hours is no easy feat. The 30 minute auxiliary lube systems I have seen are normally total loss systems. Usually with some type of air/oil mist delivery to the critical bearings and meshes. I can only imagine the amount of auxiliary oil required for a 2 hour system. I'd be very interested to see the details of your system.
A total loss of lube condition will normally result in gear scoring, due to the fact that there is insufficient oil present to produce a satisfactory EHL oil film to support the tooth contact loads. And severe scoring will produce catastrophic gear failure within a few minutes, not hours. With no oil present, an ISF'd gear flank with a surface roughness of 2AA will fail in scoring almost as quickly as a conventional ground tooth flank with a finish of 8 AA.
I started to read that NAVAIR oil analysis paper you noted, but it is 300 pages so I didn't get through it all. I haven't seen it before, so thanks for the reference!
Terry
RE: Superfinishing
Very impressed with you back ground and discussion.
To all others this is very good, good Topic & very good discussion & Imput.
Generally as a gear manufacture, we give our customers what they want.
However I discourage any process that effects the tooth Involute, & size, It's not uncommon to Grind gears upto AGMA class 15. However, It's not a lot of tolerance to play with.
If a gear is finished after heat treat. there should not be any pits or corrosion
If manufactured properly.
RE: Superfinishing
"Generally as a gear manufacture, we give our customers what they want."
Sounds like you know how to keep your customers happy! But of course, as an experienced gear house, I'm sure you still occasionally help your customers "decide" what they really want, right? Experience is probably the most valuable commodity with regards to gear design and manufacturing.
The AGMA quality classes are mostly defined by allowable profile, lead, pitch and index errors. I don't believe working surface roughness is specified for the various classes. The tight pitch and index tolerances required by the higher AGMA quality classes (ie. 11-15), while costly, are definitely necessary for meshes operating at high pitch line velocities. Any profile, lead, pitch or index errors can significantly increase dynamic loads at the mesh.
You stated that you would discourage any process that affected tooth profile and size. However, for the gears I design (mostly high performance aerospace power gears), virtually every gear profile has both face and tip profile modifications. We also sometimes use pitch diameter and addendum mods to achieve a full recess action mesh. Each gear drawing we produce has very detailed profile charts defining the tolerance limits we require for the profile mods that deviate from a true involute profile.
Producing high quality gears now days is much easier than it used to be. Especially with the current models of NC gear grinders that can grind the teeth, dress the wheel when required, grind the adjacent bearing journals, and continuously inspect the teeth, all without removing the gear from its set-up on the machine.
Terry
RE: Superfinishing
You are right! most of our customers designs are with modified involute, generally very close tolerance .0002 -.0003 tolerance. In addition also have crowns on their helical gears.
I am amazed at some of the gears we manufacture for Helicopter Power Trains, where designed & manufactured in the late 1950s & all of the 1960s.
I tip my Hat to those that could design & manufacture such tight tolerances with the technology available at that period. I can only imagine the complexity of the designs.
These gears even today if you do not have the knowledge
are really easy to scrap. It takes years and years of experience.
Heat Treat is always the key and if you make it through Heat treat it's a mile stone.
You can have the newest machinery in the world but that will not help you though heat treat. Believe me when I say this I know.
But it will help with efficiency & quality once the gears make it through heat treat.
You the designers can also make it tough or semi tough on your designs. But Generally Most gear designers have it on the ball and do make it easier for us who are doing the manufacturing. : >)
Keep up the good work
Take Care
