Assembly Move command
Anyone know if there is an option somewhere that turns off the Move command in an Assembly? In the assembly that I have it is gray and if I use assembly mode I am unable to move it as well. This is only happening in this one drawing, all of the rest I have checked it works great. The only thing I can think off is there is a option button select by mistake, but I can't find it.
SE v20 SP7 WinXP SP2
RE: Assembly Move command
jlbmech,
 If you have an error in your assembly the move option is disabled. At least that was my issue before.
hello,
is the part active?
Neg21 nailed the problem, thanks for the help all.
