Thermal problem on AMD XP 64-bit machine
I have bought an AMD phenom Quad core machine with XP 64 bit on. I am having problems in thermal stress analysis. Thermal analysis seems working fine but the displacement model where i am reading the thermal data is not giving proper results. I am comparing the results with the results i had with my old XP 32 bit machine. In short, the files are same i am running on my two pcs separately (old and new ) and 32 bit pc gives me proper results where as 64 bit machine doesnt. The error i am having in 64 bit machine is
"Deformation and/or analytical surface extent is too large as compared with the model"
I am expecting my output in microns where as the 64 bit machine is giving me 1 x e33 and with a different profile. Have any one of you had any problems???
I have checked and can say that the single analysis is OK with 64 bit machine but when the output is being read into another model, it doesnt work. Is it something to do with Abaqus 64bit edition, WinXP64bit or AMD phenon quadcore????
Sorry for being so complicated but can i have any suggestions to the problem. i would greatly appreciate.
RE: Thermal problem on AMD XP 64-bit machine
Could you upload your inp file?
