Running M-file from Simulink
Hi colleges,
Is it possible to run m-file directly from Simulink, I mean when I press Simulation/Start button?
Regards, Zoran
RE: Running M-file from Simulink
use matlab funciton block in simulink,
Yes of course it is possible !
If you want to load data, for example, you can use the matlab function block.
If you want to connect the function to other simulink blocks, you need to use the s-function block.
It is really useful to perform user-defined actions, like real-time  animations for example, even if it slozs down the calculation because the matlab code is interpreted at each iteration.
Cheers
Benoit
