Make hidden edge visible
Hello
I have a drawing, and a section view.
I want to make a hole visible, witch is not in the cut section, to dimension it's depth. (see attached picture in the red circle),
The only way I can think of doing this, is to show all hidden edges, and manualy hide all the edges I don't need, but I think there should be an easier way??,
To make just one hidden edge visible doesn't work, because i am not able to select it...
I hope someone can help me out..
RE: Make hidden edge visible
You can select an individual feature in the feature tree and choose "show hidden edges".  However, I think hidden edges in section views is pretty much not recommended.  You might do better with an aligned section view, detail view, or something like that.
-handleman, CSWP (The new, easy test)
Thanks a lot!! that's what i was looking for!!
