temporary crane loads on top of retaining wall
I have an existing retaining wall that I need to analyze for a crane load. The retaining wall was designed for a 50 psf surcharge over the heel. How do you determine the additional lateral pressures on the wall for a point load? This would be the only surcharge on the wall when the crane is present. The crane will be on site less than a day. The wall can be braced with pipe braces if necessary.
RE: temporary crane loads on top of retaining wall
I do not have a copy of this document. Could you provide a PDF of that page?
f-d
¡papá gordo ain't no madre flaca!
When analysing, i.e when using the horizontal loads, use undrained soil parameters for cohesive soils and drained parameters for coarse soils.
Thanks for the info.
http:/
Last year I was able to significantly upgrade the copy of DM 7.1 I offer, and am working on doing the same for DM 7.2.
http://www.pz27.net
