Acceptable to have assembly drawing an exploded view?
Hi all.
I have a high level question regarding what an assembly drawing should be. To me, an assembly drawing should be a three view of the assembly, with auxiliary views and sections taken as appropriate.
I have a designer (technically my boss) who insists on making his assembly drawings as exploded views. I understand why he does this from a business standpoint (we don't really have a tech pubs dept.), but as an engineer, it just rubs me the wrong way.
Anybody have any experience with using exploded views as the engineering assembly drawing? I'd like to be able to point to something and say it's a no-no.
Thanks.
Thanks.
RE: Acceptable to have assembly drawing an exploded view?
Per ASME 14.24-1989 (may be a later revision by now), para 1.4 "Preparation methods... (orthographic, pictorial, or exploded views)... are a concern of this standard only to the extent that the drawing satifies its intended purpose."
ASME Y14.100M-1998 states in para 4.9 that "Isometric or pictorial views shall be in accordance with ASME Y14.4M, and may be shown on engineering drawings provided that clarity is not degraded."
I don't have a copy of Y14.4M, but doubt that it would restrict their use.
I'm sure others will add to this.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
bg109g, you might be thinking of "level 3" (if I remember the name correctly) drawings that show a tremendous amount of detail of parts and assembly in very particular formats. This is not part of ASME standards; I think its a government requirement for particular contracts.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
If the intended purpose of the drawing is to depict how the thing goes together then I'd go for exploded.
There is no reason you can't do both on the same drawing.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
As for photos, when digital cameras because affordable (circa 1996?) I worked at a place that began to use photos for some wiring harness details. The problem quickly arose after seeing a drawing copied and/or faxed. It took several months for people to decide which gray scale setting they would use so the inserted photos would survive a few copy/fax actions. Very ugly.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
I once worked with a company that decided to make one whole project with photos of it instead of taking the time to draw it. The drawings were full of these wonderful photos. Then the customer received them and could not make copies and reduce them to smaller sheets, the photos turned black. If any changes were needed, new photos were needed, but then that specific product was shipped, the current ones were slightly different because of design changes.
Chris
ctopher's blog
SolidWorks Legion
The other side of this is that you should NOT be telling someone how to build the assembly or what methods they should be using. These should go in an assembly instruction document.
David
How do you dimension an exploded view? I've never seen it.
In my opinion, an exploded view, by itself, cannot show the correct assembly relationship and orientation for the simple reason that the parts are not attached in the view. Don't get me wrong though, I think exploded views are great for communicating information. In some instances an assembly becomes too complex to be clearly communicated by sections and auxiliary views alone. I just think that you need to also show the final location of the parts as well.
David
That said, I don't think that I have ever created such drawings without showing the assembled state and would not recommend it. I feel that an assembled view is essential to show what the envelope actually is and what the assembled part will look like.
Matt Lorono
Silicon Valley, CA
While the wording of 14.24 may not be as clear as it could be I agree that "depiction of the items in the assembly relationship, using sufficient detail for identification and orientation of the items." means showing the final assembled condition.
However, exploded views are allowed as other have pointed out, but I'd only use them in addition to assembled views when they add clarity.
I asked a similar question some time ago: thread1103-157857: Assembly Drawings - Or Instruction manuals and I think there may be another thread too around that time.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
Other product development activities are moving toward requiring exploded view drawings. Hopefully, the ASME standard can keep up.
Look at the future assembly plant...beside EACH workstation will be an exploded view drawing of some sort.
Drawings of the future will be used to do more. Example...There will be "in-process" drawings used to do things like "kit" parts...to aide in error-proofing.
As processes like FMEAs grow in importance, so will new unconventional looking drawings.
Michael
I could write a long diatribe on the issues we've faced trying to create work instructions based on CAD data before finalizing that CAD data/drawings but I can't be bothered right now.
KENAT,
I guess I need to ask for a raise since I will be doing tech pubs work in addition to my engineering duties. The company could afford it since there will be no need to pay technically competent people in the shop. Anybody can come in an assemble parts based on the funny paper simple exploded drawings that will be beside each workstation.
As an aeronautical engineer, that scares me. I realize that for some, engineering has become a repeatable process where only the process gets attention and there is no technical expertise required. Where is the accountability? What if the process is flawed in a major way because some ISO certification guy just showed up one day and got taken to lunch and boozed up, after which he signed the certificate? No sir, this ISO/system/process stuff can be dangerous and we need to be ever vigilant to make sure that "approved" processes and procedures don't end up killing someone.
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
On my site, my boss is demanding exploded views because production likes them.
Somewhere in my design documentation, I want orthogonal views with section views and whatever else is need to under what it looks like and how it works. Often, I do this on a separate arrangement drawing.
My perception of the assembly drawing is that it tells someone how to put the thing together. Assembly sequence, test procedures, orientation of components like belleville washers, and screw torques are as much a part of the design as the intended functionality.
I'm sure it's better for shop floor, but sucks for at least some other users.
That's why I believe exploded views, within reason, should be in addition to views that explicitly show the assembled state.
Also, I still can't help but think the principle of detailing the end item applies.
KENAT,
I've never seen an assembly that couldn't be fully depicted with auxiliary and section views. I have yet to see a major aircraft manufacturer depict an assembly as an exploded view as part of an FAA approved data package.
Shop documentation is another thing. If the shop wants an exploded view to assist in assembly, do whatever makes them happy. Add it to their traveller. Hold their hands to make sure the -1 goes against the -3. But when final inspection is accomplished on an FAA approved design, it must be checked in accordance with the FAA approved data.
But again, we are dumbing down our engineering documentation to cater to the lowest common denominator. I just don't like it.
However, in the commercial world especially, there's the assumption that extra documents mean extra work/cost and money can be saved by combining them in a single document. I'm not sure that's always completely true, but I'm getting tired of arguing the case. Hence I'm about to put a bunch of photos, that depict things already shown in a true drawing view as well as step by step instructions (in contravention of 14.5) on what was a nice clear assembly drawing.
ewh, I'm not sure anyone has stated exploded views are prohibited. The contention as I understand it is whether they can be used by themselves.
KENAT,
KENAT,
Man, I didn't think I'd open up a can of worms like this...
Time to break out those poles!
No,no, no, no, no - we want vague un inspectable requirements like 'approximately centered as shown in the beutiful photographs'.
Of course, as the OP seems open to veering off topic, a lot of this issue is related to de-skilling the shop floor.
Most on the shop floor can't read an engineering drawing. I thought this was where production/manufacturing/industrial engineers came in and filled the void by translating Design's requirements into the required steps to achieve those requirements. Be this as a traveller that follows the job, work instructions, fancy 3D CAD animations, cartoons, placards, specific task oriented workstations & training... Trouble seems to be, managers want to get rid of the skilled labour, without getting enough/any manufacturing engineers that can translate the drawings. Hence you end up with these abortions of so called assembly drawings.
[Sorry, I'm in a bad mood about that drawing still]
KENAT,
You're right, there is a definite movement afoot to clear the decks of all skilled workers on the shop floor. I won't be politically incorrect by mentioning that I need an interpreter to converse with some workers, but there I went and did it.
It wasn't even my @#$%#$%@# drawing in the first place. It was a pile of #$%#$% I picked up from an intern and made legibile. Then every other day they come up with some other requirement they forgot to specify that needs adding, it's now culminated in so many extra notes and photo's that it really needs an assembly procedure not just a drawing, but they don't want to do that, even when I offered to do it. They even made me take off the nice clear dimension;-(. I'm off to complain ineffectually to my boss about it.
KENAT,
As a general rule, exploded views are unsuitable for dimensions. An orthogonal view is much more suitable for this purpose. If it reaches the shop at 1:1 scale, it can be used as an assembly fixture.
Parts that attach solidly together do not require assembly dimensions. Parts that will be adjusted in some later process should be assembled to a nominal dimension, plus/minus some tolerance.
Drawings are a means of communication. You apply the views that communicate the required information. Systematically apply exploded views is just as limited as not ever applying exploded views.
