Mirror Feature Issue
I created a wing from an airfoil made using splies which is just the half of the total wing. now when i mirror the componenets in the assembly mode i see that there is difference in the volume calculated whcih causes the center of mass to be offset rather than from being in plane of symmetry. Is there any thign geometrically wrong.
Thanking you
REgards
Kartik
Thanking you
REgards
Kartik
RE: Mirror Feature Issue
No material is assigned for the right wing part.
Rob Stupplebeen
