civil 3D parcel table
i have a three closed polygons from which i created a three parcels. two things i am struggling with are:
1) when i add labels to the first parcel (line and curve tags), i force it to start the numbering from 1 with increments of 1. works fine for the first parcel. when i add labels for the second parcel, in the ADD LABELS window, i click on TABLE TAG NUMBERING and reset the start for both lines and curves to be 1; but, it does not obey, starts with the next number after parcel 1!.
2) when i create a parcel segments table, the table is not in order how i want it to be. for parcel 1, i want it to be line L1 on the first row, then line L2 and so on to the very end.'
is there something else i should be doing in this process? any suggestions appreciated. regards.
