Fastener thread shear failure
Hi, I have a question regarding fastener thread shear failure. I know that often when analyzing fastener threads its common to assume that all of the load reacts on the first two or three threads. I was wondering if its appropriate, when dealing with ultimate loads, to just claim however many threads as you need since as the first threads yield subsequent threads will pick up load (basically treat the threads the same as you would fasteners in a metallic joint for ultimate loads). The limiting factor at some point would obviously be the tensile allowable of the fastener itself.
Thanks for you help,
Dan
Dan
RE: Fastener thread shear failure
If you are concerned with a shear load on the joint, then the fastener length is selected such that the threads are not in bearing on the plates, and since the threads are not at the shear plane of the joint, the fastener (generally) will not fail in the threads (except for some cases where there is a bending moment on the fastener)
I've found that in the aircraft industry, where they use lots of standard fasteners, there are allowable tensile ratings that are readily available that cover all modes of tensile failure.
It seems that programs I've worked on with space hardware, however, they often don't have good tensile allowables that cover any aspect of tensile failure for the fastener and people separately calculate the tensile allowable of the fastener and the thread shear allowable for the fastener.
Granted I've only been in aerospace for ~8 years so can't claim to have seen it all by a long shot.
thread725-35222: Tensile capacity/minimum engagement
