asm constraints
asm constraints
I've constraint to geometries with align and touch in assembly conext. Look at the attached picture. my question is Why is touch not connected to the area of the face of the block, how can I get this result, that the cylinder only touches the face of the block.
thx in ad
thx in ad
RE: asm constraints
Suresh
RE: asm constraints
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
RE: asm constraints
but should touch in meaning of the word work only on the connected faces? Should they rename it better to tangency?
RE: asm constraints
The good news on the other hand is that there are not too many different constraints and the manual to help you. Anyone willing to experiment ought to be able to work this out without too many problems.
At present you can also learn by using mating conditions first and then after changing your settings allow the system to automatically convert some of your mated parts. In that way you may have two sets of concepts to compare and that should improve your understanding.
Best Regards
Hudson
www.jamb.com.au
RE: asm constraints
the cylinder should not lose the contact to the block face.
thx in ad
