Fastener Failure Modes
I have a question regarding fastener failure modes. I was reading through my "Spacecraft Structures and Mechanisms" textbook the other day and read the following:
"In tension, a threaded fastener with a suitable head will fail first in the threaded section, usually at the thread nearest the head."
They then go on to show how the ultimate tensile stress for the fastener is established based on this failure load as a function of the tensile area of the fastener.
I've never heard this before. I always thought that the Ftu for a fastener was that of the material and you checked the thread shear strength separately using Fsu for the material (and check capability of first couple threads).
Has anyone heard of this before? That is, that the Ftu for a fastener is some contrived value that actually reflects the threads failing rather than the tensile ultimate strength of the fastener material itself?
RE: Fastener Failure Modes
DaveAtkins
