Torispherical head sizing
When designing a torispherical head, the thickness can be calculated according to UG-32 (e) with specific values for "L" and "r", but in Appendix 1-4 (d) comes the general thickness equation for any given value for L and r.
When I used equation in UG-32 with L=D and r=0.06D I had a thickness value that from what I understand is the maximum minimum thickness, now if I start changing r value grater than 0.06D, thickness reduces.
So the questions are; what would be the recommended value for "r", can "r" be increased arbitrarily? and is there a recommended value for the head inside depth?
The only restrictions I found where:
1. L ≤ D0
2. 3t≤ r ≥ 0.06D0
Thanks for the help
1. L ≤ D0
2. 3t≤ r ≥ 0.06D0
Thanks for the help
RE: Torispherical head sizing
MOSTLY DR = D-6"
IKR = .06D
HEAD DEPTH CHANGES WITH EACH RADIUS CHANGE
