Rt. Click options Missing!
I'm hoping someone can shed some light on this. I'm working on LDC 2009, seems I loose a command each week. This time its when I right click on my mouse. I used to have the option of "select similar" that's gone, also if I selected an image I could right click and go to "image" which is no longer there. Plus, when I select say a line in the drawing and type "e" for erase in the command line it then asks me to select the line to erase. Whereas before I could select that line type "e" and be done with it. Any tips would be great.
Thanks in advance.
Thanks in advance.
RE: Rt. Click options Missing!
Thank you
Thank you
