How do you turn off the mesh when viewing results?
I have quite a fine mesh a one point in my model, and i cannot see the stress distribution as the mesh is covering and it is just a black area. How do I turn off the mesh while viewing results?
I have trawled for hours through all the options and cannot find one to turn it off or make it invisible.
Any help would be much appreciated,
phil.
RE: How do you turn off the mesh when viewing results?
It is well hidden.  I find the options in visualization fairly confusing also.
Options - Common - Visible Edges - No edges
I hope this helps.
Rob Stupplebeen
Hi Rob,
Thanks, that's exactly what I was looking for.
Thank you,
Philip.
You go to options/common and set no edges
corus
