GRiP Question, UG Manager
I am encoding a part number to UG manager using the UGMGRE command,
Is it possible, if so how, to wild card the part revision in the UGMGRE command so that the revision is sorted out by the revision rule.
Cheers,
NXJ
Cheers,
NXJ
RE: GRiP Question, UG Manager
I had no luck at all w/wildcards... I resorted to trying to get all revs and using a bubble sort. This didn't work out very well either and at the end of the day I resorted to hard-coding the rev.
If you get a solution I'd be interested in hearing about it.
SS
CAD should pay for itself, shouldn't it?
