Solid Edge v20 Text problem
Hi i am using solid edge v 20 and i have a litle problem with text formating. I set the language (bulgarian) in the text properties box chose a font but then when I am trying to write in Bulgarian all i get are some symbols. I use windows Vista 64 . Anyone have clue?
RE: Solid Edge v20 Text problem
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
you must have a font that has the needed characters within
the lower half, that is from 0 to 255. SE can't handle
Unicode chars. These are usually located above code postion
255.
dy
