What is wrong with my model--helical spring compressed by rigid plates
I created a model of a helical spring (5 coils) being compressed a two rigid plates. It didn't converge. Could any one please take a look at the file and show me what is wrong?
Many thanks,
Many thanks,
RE: What is wrong with my model--helical spring compressed by rigid plates
corus
There are messages of overclosures in the model. Either you should move the top rigid body up so that it doesnt interefere with spring surface initially and then push it down the distance you need or activate shrink fit in your rigid top vs spring surface contact by going to interefernce fit to remove the initial interference. Attached CAE model for your reference. Please look in interactions. The model completes fine.
Fayaz
