3D modal Analysis calculation package
When performing a 3D modal Analysis with one of the many software packages, I have had different responses from plan reviews within the same building departments. Most of the time my projects are approved without comment but other times....
I currently have a single family residence that is to be built with concrete bearing walls (ICF) and SJI floor joists with composite concrete floor slabs. The structure is on a view site and is all window towards the view. Because of this it is a torsional irregular type 1a building. Even so, it is extremely stiff with very little stress in the walls. The plans reviewer has requested additional information 4 times. It seems that no matter what I send it doesn't seem to answer her questions. I am temped to just do a full output dump to a PDF file and send it to her but that would run to approximately 20,000 pages. This building is your proverbial concrete sh__-house. It seams that the reviewer works mostly on wood stick framed houses and is trying to perform a full hand check on my calculations. She is asking for simplistic answers to complex question.
So what do you normally submit in the way of a calculation package?
RE: 3D modal Analysis calculation package
i won't dump a ton of paper on the desk of someone who you need to approve your work. i'd sit down with the reviewer and try to understand their difficulty ... if they're out of their depth (unfamiliar with concrete structures), throw them a life preserver ! only if you're going nowhere would i play the "let's ask your supervisor" card.
Then again, she may take a month to review your structure while she tries to learn the modeling concepts and analysis concepts that she is struggling with. During which she could nit-pick every tiny modeling decision you have made.
In this case the building is designed under the IBC. I am a licensed Structural Engineer with 16 years of experience, 7 of which are in the prestressed concrete industry. The reviewer received her civil PE two years ago. To date her requests for additional information have cost me two to three days of uncompensated work and she has found nothing that does not comply with the code. I am quite sure that if this was checked by the commercial side of the department it would have gone through without comment.
Some the complaints that she has is that I am not showing a calculation for every shear wall in the building. I used the stress envelope to find the controlling case and provided calculations of the analysis of that wall. this showed that minimum reinforcement was sufficient. NOT GOOD ENOUGH! GRRRRR!!! There are probably thirty shear wall segments.
It ended up being a nightmare
But there should should always be simple solutions to complex problems
"Good design exacts a price from our egos, but it really is a gift -- it really is freedom -- to find the simplicity in things and finally to reduce an engineering design down to where it ought to be."
John H. Lienhard
University of Houston
They do not check structural design at all. Instead, they rely on the engineering seal and signature on the drawings. Structural engineers do not customarily submit calculations although the authority could, in theory ask for them. In more than fifty years in practice, I cannot recall ever being asked.
Larger engineering firms may have a checking department within the firm to carry out a design review of major projects before applying for permits, but I doubt that many are doing a review for single family residences.
I sympathize with anyone who has to go through such a process, particularly when the authority can't engineer his or her way out of a wet paper bag. On the other hand, it may cause the engineer to review his calculations more carefully, knowing it will be scrutinized by someone else.
Best regards,
BA
I have worked as a framer and as well as an on-site engineer for a precast manufacture. If the plant personnel did not like my drawings, they would drag me out and show me the error of my ways. That "...exacts a price from our egos" if anything does. The challenge with proper simplification of the construction is that it requires diligence in maintaining a good load path. The computation is complex so that the building can be as simple as possible.
