oil cut, GOR question
What does it mean when i am told a well produces 1000 barrels of total fluid with a GOR of 500 scf/bbl and 50% oil cut? with a wellhead pressure of 2000 psi at primary production?
How much oil, produces water and gas will i be producing?
does this mean 500 bbls of oil, and 500 bbls of water with 500000 scf of gaS?
RE: oil cut, GOR question
yes
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Apologies to BigInch but no.
500 bbls water + 500 bbls oil is correct but
GOR = Gas / Oil Ratio (scf/bbl)
therefore Gas flow = 500 scf/bbl x 500 bbl(oil)= 250000 scf
regards
NMcC
You're 100% right.  1000 x 500 looked right when I got to the end of the question.  Apologies elque.
Thank you all
Thanks for the star.  I really really deserved that one. blush
Elq:
I would like to give one warning - it depends (a little) whether you are upstream or downstream.
The reservoir engineer will set up his simulation to produce a result such as the one you mention.
As a facility eng. you will receive
a) A composition
b) A production profile.
GOR may change over the years - but you are only issued one composition. Most chemical engineer will now realise that something doesn't add up.
Furthermore you should also ask the reservoir eng - how did you set up the simulation. The results may be based on a single flash at standard conditions - or a 4 stage flash a specified pressures and temperatures - you cant be sure until you ask and this data may not be given to you. And just because it was something the last time . its not certain its the same this time. So always ask.
Best regards
Morten
